Size of External Torx bolt on upper transmission mount 2011 Accord 3.5L
Old Sep 9, 2020 | 07:50 PM
Zimmy52's Avatar
Thumbs up Size of External Torx bolt on upper transmission mount 2011 Accord 3.5L
I am in the process of replacing all 5 engine mounts on my wife's 2011 Accord. I have the passenger side, front and rear active mounts installed. The upper transmission mount under the air filter has a external torx bolt and I am trying to find out what size the external torx bolt is. In the shop manual it states: NOTE: Do not remove the TORX bolt (B) from the upper transmission mount. If the TORX bolt is removed, the upper transmission mount must be replaced as an assembly. I guess Honda wants to sell you the aluminum mount and the engine mount in tandem. I thought this would be the easiest mount to change. The largest External Torx star socket set I could find is E24 on Amazon. I don't mind buying the sockets if I know I have the right size. Appreciate the help of any experienced DIYer.
Old Sep 10, 2020 | 09:14 PM
Seanjordan20's Avatar
I've never needed anything bigger than a 24 on a Honda or any car. I'd say get it from Amazon if it doesn't fit send it back.
Old Sep 11, 2020 | 11:20 AM
Zimmy52's Avatar
Thank you
Old Aug 8, 2021 | 09:35 AM
sirhhenry's Avatar
Bought the Torx bolt kit and used E24 to remove. For me was very tough at first and repeatedly applied PB Blaster and used a 24inch breaker bar.
Rocky
Apr 29, 2017 07:54 AM
slickgeek
May 17, 2014 08:03 PM
patwguinness
Jul 12, 2011 03:40 PM
and4rik
Feb 9, 2010 08:50 PM
bedwards97
Mar 14, 2007 03:51 PM
