Slight wobble/shakes on highway
Old Mar 21, 2025 | 05:10 AM
dtnieberding's Avatar
Originally Posted by PAhonda
Nobody can tell you when the ball joints will fail, so you are at risk of injuring yourself or others when driving this vehicle.
The boots are replaceable, so any ball joint that is still tight can get a new boot and grease. Loose ball joints like the tie-rod end should be replaced. If you go to the effort to replace the boots, then you are a few bolts away from doing the CV joint and just replacing the ball joint(s). Difficult call on what to do since your budget is tight.
DIY saves you money. I grew up in your region of the country, so removing any suspension stuff is potentially much harder as road salt causes rust making fasteners hard to remove. I bought my TSX in Cleveland, and when I had a Houston shop replace the clutch, the mechanic asked me where this car came from. He told me a few 12mm bolts are now 11mm!
I am, unfortunately, driving it this week. And I know it's risky, but I don't have a better option. I attempted to replace the tie rod a few days ago, but I could not get the outer separated from the inner. Tomorrow, I will have access to better tools, so I will make sure it gets done.
I'm not gonna bother replacing the rest of the boots. The other joints are good. And this car is getting close to end of life/scarp yard. If I end up selling it to an individual, I will make a list of known problems, including the broken boots.
Old Apr 3, 2025 | 08:26 AM
Update: I tried again to replace the tie-rod, but I couldn't get the nut off. Soaked it in catalyst (PB Blaster), but would not budge. My impact wrench and torch disappeared (stolen?). So I couldn't apply heat or use the impact wrench. I gave up and took it to a shop. For $137, it got replaced. At that point, I was confident it was safe to drive, but it still shakes a bit on the highway.
The following day, much more severe problems occurred. So I rented a car for 6 days. Then I bought a 2010 Civic, in perfect shape. The Accord is still running and I have it for sale. Hopefully someone can save it from the junkyard.
Old Apr 9, 2025 | 07:05 PM
Update: I attempted to replace the tie rod again but I couldn't get it off. Some of my tools have disappeared (impact wrench, torch, etc), so I couldn't apply heat and such. I took it to a shop, and they replaced the tie rod for $137.
The following day, I experienced a much worse problem. It kept stalling and not starting again (electrical problems mentioned in another thread). So I ended up renting a car for 6 days, and then I bought a 2010 Civic in pristine condition.
I took the dash apart on the Accord and couldn't find any specific wiring issue, like a short. But after moving the wiring around a bit, the stalling and not starting issue has not reoccurred. It's running fine now, but I'm selling it.
perryau1996
Aug 22, 2014 07:55 PM
brittaylor
Jul 10, 2014 02:33 PM
ndp125
Aug 21, 2009 10:32 AM
pandadesigns
May 26, 2009 11:49 AM
10th dude
Nov 30, 2007 04:24 AM
