Smells after driving
Old Jun 24, 2008 | 08:08 PM
Alekat's Avatar
Default RE: Smells after driving
As you are probably aware - coolant leaking onto a hot surface has a sweet smell.
Look very close at the front of the valve coverseal for slight oil seepage onto the the exhaust manifold.
Old Jun 24, 2008 | 10:34 PM
finch13's Avatar
falkore, one of the few times I'm calling BS on you.
Gauge no worky, replace sending unit, gauge worky. Hole for unit leaks coolant not oil. Sorry short post, lame HAF.
I'm going to check the temp with the infrared next time I'm at g-pas.
Old Jun 24, 2008 | 10:35 PM
finch13's Avatar
no i have not check the t-stat either. everything worked great previous to shearing the sending unit. would expect the same when replaced. will check sooner or later, I know the enigine isn't overheating. i drove without the unit for a month, not a prob.
Old Jun 25, 2008 | 08:15 AM
Slithersilver (original post)...
Whats new? Have you identified the smell?
Old Jun 25, 2008 | 09:59 AM
slithersilver's Avatar
First of all thanks for all these discussions.
I haven't still identified the smell and moreover, yesterday was rainy day so no time for that.. i'll get back to guys as soon as i find something worth mentioning.
Some of the comments are quite cryptic to me, because i am a way too beginner in components of car.
By the way, i recently fixed the problem of not getting start during hot day by fixing main relay in my Accord 1993. I found useful information in this forum.
As this is 15 year old car with 200K, i don't really want to spend too much just to diagnoses. think looking at the temperature using Infrared will too much cost.
Any suggestions?
(Note: i check the coolant level in radiator, its full)
Thanks..
Silver
(Nebraska)
Old Jun 25, 2008 | 10:47 AM
Smell ofcoolant in radiator - not the same as your original question?
Which things are cryptic? We got way off track with some postings.
Valve cover is very top cover on engine. Oil leaking from the front of that onto the hot exhaust manifold? Oil leaking out ANYWHERE?
Old Jun 25, 2008 | 03:13 PM
  #17
May be this might be helpful in diagnoses.
There was oil leak from the engine. The oil got into the spark plug. And i Had to change the valve cover gasket.
I don't see any sign of oil leak at least in the spark plug hole. Other outer engine looks dry.
The car drives very smooth (even its 15 years old).
Hope this helps.
Silver.
Accord 93, 200K
Old Jun 25, 2008 | 03:27 PM
  #18
What about a smell like burning rubber? A little bit of that is normal from tire wear, but maybe the suspension alignment is way off?
Old Jun 25, 2008 | 03:36 PM
  #19
RTexasF's Avatar
Super Member
The temp guage is for coolant NOT oil.
Old Jun 25, 2008 | 06:21 PM
  #20
falkore24's Avatar
ORIGINAL: JimBlake
Falk, what years is the temperature gauge for oil? I wasnt aware of that. Its for coolant on all the HondAcuras Ive owned.
I guess I'm just wrong on this one ..... could've sworn it was oil temp.
dboogie2288
Nov 11, 2010 07:34 AM
fusionstar
Jul 6, 2010 01:06 AM
HondaAccordNewb
Jan 16, 2008 01:16 AM
kturnerga
Sep 21, 2006 12:22 AM
