92 Accord smells like rotting veggies, dung
Old Sep 15, 2006 | 04:08 AM
kturnerga's Avatar
Default 92 Accord smells like rotting veggies, dung
Hello
I thought I had fixed the issue of the cow dung smell from the Honda's vents. It rained heavily yesterday and I got into my car and smelled a rotting vegetable smell. I had tried a month or two ago to spray Clorox and Lysol into the vents but to no apparent avail. Is there an air conditioner filter as in the '96 models? How do I get to the intake for the A/C system?
Or do I just need to drive the machine into a vat of Listerine?
Thanks
Ken
Driver of the General Tso (Red 92 Accord LX)
Old Sep 15, 2006 | 05:16 AM
deserthonda's Avatar
Default RE: 92 Accord smells like rotting veggies, dung
cabin filter did not start till 98 .
you need to remove the evaporator from the car, take it apart, remove all the junk that might be attached to it, clean it with soap and water, replace the 2 insulators, spray the casings, insulators and evap with some good smelling lysol or fridy fresh,,,,,,put it all together ..
this is the only way that the bad smell will not come back . if you spray deodorizing in the vent , it is like putting a band aid on a 5 inch cut ...
now,, to do so you need to evac and recharge the a/c system.
Old Sep 15, 2006 | 09:35 AM
**This works like Desert says, I had to do this to my 1991 Accord a couple of years ago because of the same problem..**
ORIGINAL: deserthonda
Old Sep 16, 2006 | 01:22 AM
kturnerga's Avatar
Fellas:
Thanks for the info. I wonder if the housing can be removed from the lower 1/2 of the evaporator and some strong non-acidic cleaner sprayed onto the evap without having to discharge the R-12 (or more correctly paying someone to do this) ?
Also is the intake under the grille between the wiper arms and the windshield? I might try to spray Clorox inside the intake.
Thank you
KAT
Old Sep 21, 2006 | 12:22 AM
hondadude's Avatar
If you want to prevent this problem, use fresh air setting and turn off the A/C for the last few minutes of every trip. The mold and stink is caused by too much moisture left in the evap housing when the car is sitting with no air flow.
dboogie2288
Nov 11, 2010 07:34 AM
fusionstar
Jul 6, 2010 01:06 AM
guinnessmike
Aug 27, 2009 11:40 AM
slithersilver
Jun 25, 2008 06:21 PM
HondaAccordNewb
Jan 16, 2008 01:16 AM
