Smog questions
Old Apr 3, 2014 | 07:40 PM
Mario Locatelli's Avatar
Default Smog questions
So I took my car to get smogged and failed. I have only a aftermarket cold air intake. Below are the failures. Could you guys that know about emissions maybe point me in the right direction on what might need to be fixed?
Thanks
FIRST TEST IS AT 15MPH
SECOND TEST IS AT 25MPH
CO (%) NO (PPM)
MAX MEASURED MAX MEASURED
0.36 0.59 (FAIL) 493 563 (FAIL)
0.35 0.63 (FAIL) 738 608 (PASS)
Old Apr 4, 2014 | 08:33 AM
It might help if we knew what kind of car this is...
Old Apr 4, 2014 | 02:22 PM
1995 Accord
2.2L nonVTEC
SOHC
F22B
Old Apr 5, 2014 | 08:48 AM
Excess CO occurs when rich condition (not enough O2 for fuel) occurs.
Look for fuel leakage into system; fuel pressure regulator diaphragm ruptured (sniff vacuum reference line for gas smell), leaking injector, faulty O2 sensor, excess fuel pressure (unlikely).
Is this car obd1 or obd2? Is Check Engine Light on? If yes, then what codes.
Old Apr 5, 2014 | 09:14 AM
You failed part of the NO emissions, so I would clean the EGR port.
Here is a video on how to do this:
aloha_bruddah
May 10, 2014 05:19 AM
jetblack3s
Nov 25, 2006 04:38 PM
thunder_x
Nov 6, 2006 08:26 PM
sbecraft0
Sep 27, 2006 03:26 PM
93Accord10thYear
May 17, 2006 08:00 PM
