Squealing noise from alternator belt! PLS help
Old Oct 16, 2008 | 11:47 PM
jenny
Default Squealing noise from alternator belt! PLS help
Ever since I got the alternator belts changed, I have a horrible, completely imbarrassing squealing noise especially when it's cold, wet, when I start it up, slowing down and sometimes turning corners. Putting belt spray helps but doesn't last. Tightening it doesn't seem to work.... What else can it be? Is it serious and how do I get it to stop?
Please help.
Old Oct 17, 2008 | 07:05 AM
08coupex's Avatar
Default RE: Squealing noise from alternator belt! PLS help
You might have the wrong size belt on or you need to tighten the belt.
Old Oct 17, 2008 | 07:07 AM
Tightening the alternator is tricky because access to the traveling bolt lock nut below the alternator. Here are the steps:
1) Loosen alternator hinge nut (easy access w/ 12mm socket and ratchet).
2) Loosen alternator traveling bolt lock nut under the alternator. Very difficult to access w/ ratchet+12mm socket or 12mm open/closed end combination. I use an offset closed end wrench to reach and loosen the nut ~ 1-2 turns. It is also possible to access w/ 1/4" ratchet, 1/4x3/8" adapter, and 3/8"-12mm socket. This combination will reach the nut and allow engagement.
3) Use a ratchet, 12mm socket and extensions to reach the adjustment bolt beneath the alternator. It helps greatly if you have some wobbly sockets to allow "curved access", but I think you can make work w/ straight extensions. This bolt moves the alternator around the hinge bolt to change alternator position.
Old Oct 17, 2008 | 04:23 PM
jenny
Thanks guys! i'll let someone else do it for me this time.
aking
Apr 4, 2011 11:19 AM
heathb
Nov 9, 2010 05:44 AM
rle85048
Aug 21, 2009 07:04 AM
Brig
Jan 10, 2008 06:24 PM
TACORICAN
Aug 25, 2007 07:29 PM
