Steering stiffens after engine heats up.
I have a 1998 model of honda accord and after sometime of driving my power steering stiffens. I have changed the power steering fluid pump yet the problem persists. Kindly assist.
The foaming would be where I would be concerned......usually that means "air" is getting into the system....btw air will compress,,,,just like air in the brake system,,,,doesn't work.
So I would start by checking for a bad o-ring on the connections, hoses or a loose return hose first.....can't remeber if the 6th gen's had the "filter" in the bottom of the PS res.....seen those get dirty and cause sim issues.
EDIT: the fluid is not "so much" a concern based upon the feedback.
mikebuddy
May 22, 2015 01:12 PM
redbull-1
DIY Answers.
Dec 23, 2012 01:47 PM
thunder_x
Aug 11, 2007 10:31 PM
