Steering wheel vibration at highway speeds
Old Jun 20, 2016 | 06:28 AM
cukaracha's Avatar
Default Steering wheel vibration at highway speeds
Hi all,
I noticed my steering wheel vibrates around 70 - 80 mph, and then starts to get better at faster speeds. It doesn't start vibrating until 70mph. The vibration seems to originate from the front driver wheel and I can feel it in my feet as well.
This happened with the stock rims and tires. When I swapped them for a (used) set of aftermarket rims and tires from my other car, the same vibration was still there. I already checked tire pressure, and alignment seems more or less in check. I don't have any clicking/grinding noises that would indicate bad ball joints or axles or wheel bearings. No noises from the struts/springs either.
My next guess would be a bad outer tie rod? What do you guys think?
Old Jun 20, 2016 | 06:32 PM
rockhoundrob's Avatar
Could be lose tie-rods, wheels out of balance, bad shocks.
I have a shudder, and it is caused by warped brake rotors. But it vibrates at higher speed, but when I press on the brakes, it's WORSE.
rblack84
Mar 25, 2016 02:07 PM
MNAccordOwner
Aug 2, 2012 04:20 PM
thunder_x
Nov 2, 2007 06:11 PM
00AccordLX5spd
Mar 22, 2007 06:36 PM
sanchezcruz_20
Jan 30, 2007 02:43 PM
