Sticky Window/Access Door Panel
Old May 31, 2011 | 11:07 PM
Tommy G's Avatar
Default Sticky Window/Access Door Panel
Hello there. My "92 LX has a back right window issue. Like a fool in the 90 degree weather I tryed the back right window switch today whiich I've known not to work since I've owned the car and sure enough it rolled about half way down before quiting on me. Now it is stuck in the halfway position. Are there any tips you can help me out with as far as how to access the door panel without tearing it up.
Also, I have already replaced the main switch panel on the drivers side with one from a junk yard last year because the other windows were experiencing similar issues but I was always able to get them up with the exception of the back right. After replacing the main switch all window worked fine with no problems with the exception of the back right which has never worked... Until today... Stuck in the halfway down position...
Guess I just need to get in there and check the connections??
Old Jun 1, 2011 | 07:04 PM
If you don't have a manual already, check the DIY section for one you can download. Best I can say with getting the panel off without tearing it up, take your time.
It will also help with the testing of the motor (Sec 16, pg 242).
bnewall1
Jun 22, 2015 03:24 PM
schaicho24
Jan 6, 2014 05:45 PM
fvansan
Feb 19, 2013 08:58 PM
ex man
Jul 2, 2012 07:36 PM
navyned
Jan 24, 2012 07:32 AM
