strut/ spring help
Old Jun 3, 2013 | 03:35 PM
cartwentyfour's Avatar
Default strut/ spring help
Installed new lowering springs, struts, bushings, mounts, everything brand new. After a day of driving the front struts are not centered in their mounts. Both struts tilt to the center (inside) of the car. Everything is tight, nothing loose. I can hear the strut rod making contact with the mount. HELP! Springs are Skunk2, 2" drop, struts are Truhart.
Old Jun 3, 2013 | 06:22 PM
I've moved this to General Tech - please read the posting rules/stickies of the DIY section.
Old Jun 3, 2013 | 11:26 PM
95Coupe_360's Avatar
i know that sometimes if you tighten certain components of the suspension it can actually damage the suspension...some parts should allow some movement for the struts and springs to work properly...another thing is that it may possibly be to much of a drop for the body you have. i wouldnt want to drop my 95 2" with just lowering springs...but coilovers and i am fine with 2"
trystendaycey
Aug 3, 2011 12:36 PM
kris_loehr
Sep 21, 2010 03:30 AM
el toro
Nov 1, 2006 09:20 PM
KJ
Oct 10, 2006 02:47 AM
