Stuck in park / battery dead
Old Apr 6, 2008 | 11:33 AM
Richlady's Avatar
Default Stuck in park / battery dead
I just purchased a 2002 Honda Accord Ex V6 with 76000 miles and I LOVE this car!
However I did not read the reviews until after my purchase.
Well now 3 days into it the car was stuck in park and I finally got it out of park by pressing the shift lock release which it is still hard to shift. Now this morning the battery is dead!!!! The horn works, the brake lights work, I just don't get it???
Old Apr 6, 2008 | 12:38 PM
RTexasF's Avatar
Super Member
Default RE: Stuck in park / battery dead
Once you get it started have the battery tested, you might just need a new one. As for the transmission being ornery, I can't assist there.
Welcome.
Old Apr 7, 2008 | 01:31 PM
Richlady's Avatar
Battery was bad. Replaced it and still have the problem. Had alt. tested is was fine. Horn works and I have brake lights. Is it the solenoid by the shift lever? Does anyone know the part # and how to replace it? thanks in advance!!!
Old Apr 7, 2008 | 01:38 PM
Yes, the solenoid is down by the shift lever. First you need to figure out if the solenoid itself is bad or the circuit that drives the solenoid.
Old Apr 7, 2008 | 02:19 PM
Richlady's Avatar
Could you explain how to check? thanks
Old Apr 7, 2008 | 04:51 PM
I'm a little vague without a repair manual in front of me... With a multi-meter you'll want to see if the solenoid is getting power. If it IS, & still doesn't work, then the solenoid is bad.
Other possibilities...
Solenoid clicks (can you hear it?) but the little lever & latch is broken & doesn't release the shift lever.
Car's wiring is not sending power to operate the solenoid. You'll want a wiring drawing for your car to tell you how & what to check.
A common problem is a bad switch down at the brake pedal, but that's OK because you said the brake lights work.
ps...
It just occurred to me that if the little lever & latch were broken, then you would NOT be able to release it with the key.
Lenno
Jan 29, 2012 07:45 PM
ohill1981
Jun 16, 2011 11:48 PM
campervan12000
Jun 15, 2011 07:23 AM
hipmatt
Nov 4, 2007 06:44 PM
garye
Jan 9, 2006 04:02 AM
