Stumped
Old Jun 3, 2014 | 08:45 AM
rich983's Avatar
Default Stumped
I currently just replaced the motor in my 1996 Accord sedan (f22b2) automatic, non vtech with the same exact motor. It idles normal, no check engine light. Runs fine, BUT when it gets to 3000 rpm it stutters. It doesn't shut off though. Can somebody please help?
Old Jun 3, 2014 | 09:03 AM
Does it go above 3,000rpms after stuttering, or it refuses to go higher than that?
Old Jun 3, 2014 | 10:29 AM
rich983's Avatar
I haven't tried to push it past the 3000 rpm in fear it will damage the motor.
Old Jun 3, 2014 | 11:19 AM
Is Check Engine Light (CEL) coming on for 2 secs and going off when engine is started? This is CEL operation test. If not, CEL bulb may be out.
Suggest also checking by shorting service check connector (blue 2 wire, red and grn/blu, under glove box). If Check Engine Light stays on continuously, this indicates the back-up engine control is in operation (fail safe). Fix is to substitute a known good ECM.
Used ECM's are readily available at reasonable prices on ebay and car-part.com. Be sure to get an ECM w/ exact part number as original.
Old Jun 3, 2014 | 05:31 PM
Can you humor a stupid old guy - what are the three wire colors that are plugged into the MAP sensor?
drummer1279
Oct 30, 2008 08:57 AM
toicy4ya
Aug 19, 2008 08:55 AM
gvox
May 9, 2007 12:33 PM
trinitron12
Apr 29, 2007 08:05 PM
Timmay
Jan 25, 2007 08:47 PM
