Summer: Water pump?
Old Apr 21, 2008 | 12:39 PM
Default RE: Summer: Water pump?
If your dad did the alignment, I gotta ask his level of experience.
Did he check for loose stuff? My first thought about your vibration is loose ball joints, or loose bushings somewhere in the suspension.
Old Apr 21, 2008 | 06:30 PM
deserthonda's Avatar
double chk the balancing make sure that it is as close to zero weight needed as possible use a machine that has a FINE mode , switch frt tires to rear and test drive ,,if shaking is gone you found the problem
if shaking is still there, like Jim says, inspect the frt suspension for loose or worn components
ball joints, inner+ outer tie rod , upper contor arms, etc etc..
blacknight07644
Jan 9, 2008 08:50 PM
MacLeod
Sep 16, 2007 08:01 PM
Mpwr
Jun 20, 2006 02:23 AM
JoeBlowRacing
Aug 9, 2005 05:34 AM
