Is there a way to bypass or remove?
Old Aug 17, 2012 | 02:26 PM
firefighter44's Avatar
Almost A Senior Member
Default Is there a way to bypass or remove?
Im talking about the "safety" feature that stops the drivers door lock from locking when the lock button is pushed?
I doubt that this is an error with my car as when i hit the lock button all doors lock and then the drivers door unlocks to keep you from locking your keys inside i guess
it is just annoying to have to stop and lock the drivers door with the key every time i stop anywhere.
So the question is can i bypass or stop this from happening and make it so when i hit lock all doors lock and stay locked.
Old Aug 17, 2012 | 02:56 PM
It's probably possible, but would probably require disabling the power door locks. This function is built into the power door lock control unit in the driver's door panel.
Its purpose is to prevent accidentally locking keys in car.
Old Aug 17, 2012 | 03:02 PM
Dr. Drivability's Avatar
if i remember correctly you can lock it if you pull the inside door lever and hold it, then hit the door lock. can't remember if it worked for your year or even for power or non-power only??? try it out!!!
Old Aug 17, 2012 | 05:23 PM
That is true.
Attached Thumbnails Is there a way to bypass or remove?-drivers-door-lock.jpg
Old Aug 17, 2012 | 07:12 PM
That is very interesting, i tried it and it does infact work if you hold open either of the door handles. Nice, Thanks guys
Old Aug 17, 2012 | 08:13 PM
Now just be careful so you don't have to come back & tell us you locked your keys inside...
Old Aug 17, 2012 | 09:31 PM
that's what hammers are for
Old Aug 17, 2012 | 09:37 PM
Don't worry i keep a spare key at the house!
darkgreen18290
Oct 2, 2010 11:53 PM
HondaAccordEX94
Apr 4, 2010 05:08 PM
claggie
Jan 13, 2010 09:03 AM
cyberfriend
Jan 22, 2009 11:24 AM
jose310
Jan 6, 2009 05:02 PM
