ticking in engine
Old May 2, 2011 | 11:41 PM
taryn1's Avatar
Question ticking in engine
Just bought a 94 accord last week, when i got home I noticed it had a pretty good leak.
checked all fluids and they were full, woke up next day started the car and drove about a mile from my house and it was like I had no power and wouldnt go into gear. Got it home checked the tranny fluid and it wasnt reading anything on the dipstik. I pumped 2 quarts into it checked the dip stick again and was reading full. Now I have this bad ticking problem, it sounds like its coming from the tranny does anybody know what that could be? Or what that is causd by? After filling the tranny fluid took it for a test drive and it seemed fine, its just that ticking that Im worried about. Any help would be greatly appreciated, Im new to the honda scene so Im sure you will see me a lot asking a ton of questions. Sorry such a long thread.
Old May 3, 2011 | 12:24 PM
Two observations:
Either the fluid was low when "checked all fluids and they were full". It's not hard to make a mistake on the ATF level.
Or, the fluids were full and you still have a leak that has not been repaired. Check for Leaks!
Regarding the ticking noise. Does this noise go away when car is stopped, shifted to N while moving, accelerating only, steady speed, decelerating, or always present when engine is On and moving?
Could it be a engine valve ticking?
Old May 3, 2011 | 12:32 PM
Also when engine is running you can use a stethoscope to pin point where that sound is coming from.
Old May 6, 2011 | 11:01 PM
taryn1's Avatar
The ticking noise seems to be coming from the transmission. I did a drain and fill on the tranny using the tranny fluid straight from honda. Even after doing the drain and fill the ticking noise still coming from tranny. I went under the car to check for noise and i can hear it really good coming from the bottom of the transmission. its a constant noise whether its in idle or im out driving around. any suggestions?
Old May 6, 2011 | 11:10 PM
Ive never had a ticking transmission before-so no help here..But call a Honda Dealor and ask them if they have had the same complanits called in before.
Old May 7, 2011 | 07:18 AM
If you put car in D and hold brake, does the noise persist? If yes, and your're sure its from trans, the hydraulic pump must be making the noise. Nothing else is turning,...I suspect, but not absolutely sure.
Also torque converter is turning (tied to engine), but this is at interface between trans and engine, not the transmission where you said sound is located.
Hydraulic pump is major component and not repairable w/o pulling transmsision. That said, there's not much downside to continuing to drive.
wheeler418
Jul 26, 2011 08:53 AM
weekendwrench
Oct 18, 2008 07:16 PM
Lance Link
Feb 8, 2007 08:21 PM
goofy_addict
Oct 10, 2006 03:28 AM
cwalti
Dec 17, 2005 01:23 AM
