Timing Belt
Old Sep 21, 2009 | 10:20 AM
Zeke Fishburn
Default Timing Belt
So my car is a 2002 LX 4cyl. with 100,000 miles. I am taking it to a mechanic, someone I trust, to do the work.
I am simply researching what is the process to replacing the timing belt, not a step by step explanation for me to do it in my garage just a "make sure and replace this" while they're in there kind of a deal.
The car runs fine and I am just curious.
What else should be replaced as preventative maintenance when they do the timing belt?
Thanks in advance,
Paul
Old Sep 21, 2009 | 11:17 AM
You'll get various advice about this, mostly along these lines...
2 timing belts (one for cam, other for balance-shafts)
new water pump
new oil seals for camshaft, balancer shafts
new tensioner pulleys (for the 2 timing belts)
No real guarantees, but chances are one or more of these things will fail before ANOTHER 100k miles, and then you'll have to repeat all that labor $$$ to remove the timing belts all over again. If you were gonna do the work yourself, then it depends on your threshold of pain for re-doing all that work.
I've heard different advice for the shaft oil seals. Some people say if they're not leaking, leave them alone.
Old Sep 21, 2009 | 11:53 AM
deserthonda's Avatar
i would add to what Jim suggested......... the crank seal + alt and p/s belts,and have them install a retainer on the balan shaft seal ,
Old Sep 24, 2009 | 10:22 AM
Zeke Fishburn
Thanks for all your help.
john_pyro
Aug 4, 2019 05:06 PM
5.0stang
Apr 23, 2013 06:37 PM
ss485
Feb 23, 2011 08:18 PM
Jay 3rd
Feb 17, 2008 10:54 PM
Tony1M
Apr 1, 2007 05:42 PM
