Timing Belt
So my car is a 2002 LX 4cyl. with 100,000 miles. I am taking it to a mechanic, someone I trust, to do the work.
I am simply researching what is the process to replacing the timing belt, not a step by step explanation for me to do it in my garage just a "make sure and replace this" while they're in there kind of a deal.
The car runs fine and I am just curious.
What else should be replaced as preventative maintenance when they do the timing belt?
Thanks in advance,
Paul
Thanks in advance,
Paul
You'll get various advice about this, mostly along these lines...
2 timing belts (one for cam, other for balance-shafts)
new water pump
new oil seals for camshaft, balancer shafts
new tensioner pulleys (for the 2 timing belts)
No real guarantees, but chances are one or more of these things will fail before ANOTHER 100k miles, and then you'll have to repeat all that labor $$$ to remove the timing belts all over again. If you were gonna do the work yourself, then it depends on your threshold of pain for re-doing all that work.
I've heard different advice for the shaft oil seals. Some people say if they're not leaking, leave them alone.
new water pump
5.0stang
Apr 23, 2013 06:37 PM
