Timing Belt 97 Accord lx
Old Feb 12, 2009 | 07:59 PM
jimmy's Avatar
Question Timing Belt 97 Accord lx
Hi there
I got my first car 97 accord lx standard 230k I got the back and the front brakes, cv boot changed and balanced the wheels and oil changed and all the fluids are filled up BUT can u guys please tell me how would I know if I have to get the timing belt change or any other stuffs
THanks in advance for help!!
Old Feb 12, 2009 | 09:08 PM
This question comes up fairly frequently. What were you told by the seller? Are there any records of previous service. If yes, you might inquire w/ that facility to see if TB service has been performed.
I tried similar inquiries after I was told by seller that TB had been replaced on a Acura 2.5 TL. I was never able to confirm anything, and decided to perform the TB service. Liklihood is you will be in same position.
I'm not aware of any way to inspect a belt and tell when installed or how many miles accumulated. Old belts I've removed didn't look much different from the new replacement belts.
Old Feb 12, 2009 | 09:15 PM
Your safest bet is to just replace it if you can't prove when it was last done.
Sometimes you can till if its newer by if you can still read the writing on it, as it normally wears off with age.
Old Feb 13, 2009 | 06:39 AM
Inspection isn't very reliable. I've taken off the belt after 100k miles & found it looking good.
john_pyro
Aug 4, 2019 05:06 PM
5.0stang
Apr 23, 2013 06:37 PM
ss485
Feb 23, 2011 08:18 PM
Jay 3rd
Feb 17, 2008 10:54 PM
Tony1M
Apr 1, 2007 05:42 PM
