Timing Belt Help
Old Dec 14, 2013 | 11:15 AM
  #31
kris_loehr's Avatar
You can snap a camshaft with timing belt tension to high.
Old Dec 17, 2013 | 05:25 PM
  #32
You should be able to twist the belt (on the long span at the front) only just 90-degrees.
It really does look like the belt is too long. Some combination of parts that you used for this R&R?
Waterpump has the same diameter pulley?
Idler pulley is the same diameter?
Is the "other end" of the idler-pulley-bracket hooked on the wrong place?
Old Dec 19, 2013 | 04:24 PM
  #33
RobinsonRicer's Avatar
Everything looked exactly like what was already there. But its making the whining noise that the mechanic said was due to the tensioner being too tight. The engine runs fine as far as the timing goes. Aside from some coolant complications, I have a new thread about that. The brand of kit was "SuperAuto".
john_pyro
Aug 4, 2019 05:06 PM
5.0stang
Apr 23, 2013 06:37 PM
ss485
Feb 23, 2011 08:18 PM
Jay 3rd
Feb 17, 2008 10:54 PM
Tony1M
Apr 1, 2007 05:42 PM
