timing belt replace
Old Jan 26, 2023 | 02:24 PM
  #21
It won't hurt to replace the thermostat. I suggest an OEM honda version. I don't consider the thermostat an maintenance item and would only personally replace if you have coolant temperature issues where the car takes forever to warm up to operating temp, or if it was stuck closed and overheats.
It really doesn't matter that you live in FL. The coolant temperature gets to around 200 °F, so a northern thermostat will see the same temps as a FL thermostat.
Old Jan 26, 2023 | 02:44 PM
  #22
btartus's Avatar
got it thanks! yes I got a OEM thermostat. car warms up to operating temp pretty quick. dont think there are any issues. ill just hold the part for now.
bt
Old Jan 26, 2023 | 07:48 PM
  #23
btartus's Avatar
is the oil pump accessible while doing the timing belt? if you know. I purchased a oil pump seal/gasket, as I have a few minor oil leak issues. nothing major.
DesertRoads
Mar 7, 2020 08:23 AM
Moddage
Apr 4, 2009 08:32 PM
ally
Jan 22, 2008 03:09 AM
TACORICAN
Jun 11, 2007 07:44 PM
00AccordLX5spd
Apr 1, 2007 08:25 AM
