Timing Belt Replacement
Old Jun 22, 2010 | 10:26 PM
wheelieking's Avatar
Default Timing Belt Replacement
Hi guys, I'm new to Hondas and about to replace the timing belt on an '01 Accord. I already have the crank pulley holding tool, is the bolt reverse thread or normal? I've done this before on other cars, but like I said first time under the hood of a Honda. Any suggestions as to the order of disassembly or unique methods required?
Old Jun 22, 2010 | 11:16 PM
corvetteking's Avatar
Do a thread search... There are several that involve this subject... It will help you greatly...
Old Jun 23, 2010 | 05:45 AM
The crank-pulley bolt is right-hand thread but it's usually VERY tight. There's threads about this job, if you have a 4-cyl engine it's about the same for 1990-2002.
Old Jun 24, 2010 | 05:38 PM
I found one with someone describing the need for crank and cam seals.... It was an older model and I'm doing an '01. Is there really a need to break ANY seals?
Old Jun 24, 2010 | 10:35 PM
Well, it's 9 years old. But I usually don't disturb them if they're not leaking.
john_pyro
Aug 4, 2019 05:06 PM
5.0stang
Apr 23, 2013 06:37 PM
ss485
Feb 23, 2011 08:18 PM
Jay 3rd
Feb 17, 2008 10:54 PM
Tony1M
Apr 1, 2007 05:42 PM
