Timing For A F18a
Old Dec 12, 2006 | 11:55 PM
sejo_tt
Default Timing For A F18a
Setting back up the timing for my 93 accord it has a F18A engine in it,I need help in properly timing it because I setup the timing with the marks on the cam and the crank but getting loss of power and it cutting off any help please.
Old Dec 13, 2006 | 12:16 PM
hondadude's Avatar
Default RE: Timing For A F18a
A timing light will tell the tale, or you could take off the top belt cover and bring the crank to TDC and recheck the cam timing.
I'm assuming the T-belt was just replaced?
Old Dec 13, 2006 | 02:36 PM
It's not clear to me whether we're talking about spark timing or camshaft timing...
Old Dec 13, 2006 | 05:24 PM
huzzsaba's Avatar
Are you sure its a F18 A? I am pretty sure they have the F22a
Old Dec 13, 2006 | 06:08 PM
sejo_tt
Let me try to narrow it down a bit, Yes it’s timing belt change and we used a timing light And also it is a F18a engine, This engine worked fine before the belt change just wanted to know if there is any other markings to follow on the cam and crank, also is there any online manual on timing this engine.
Old Dec 13, 2006 | 06:15 PM
hondadude's Avatar
The timing light showing the red mark or the white mark?
There should be a total of 4 notches on the crank pulley; white is TDC then there are 3 grouped together showing BTDC marks, the center of those 3 has a red paint mark.
As far as changing the timing, loosen the 3 12mm bolts at the dist housing and rotate the dist.
I'm still placing my bet that the timing is a tooth off, and pulling the top belt cover and rotating the crank to TDC will tell the whole story.
Old Dec 13, 2006 | 10:44 PM
sejo_tt
Thanks Will Try And Let you know.
john_pyro
Aug 4, 2019 05:06 PM
5.0stang
Apr 23, 2013 06:37 PM
ss485
Feb 23, 2011 08:18 PM
Jay 3rd
Feb 17, 2008 10:54 PM
Tony1M
Apr 1, 2007 05:42 PM
