Torque Wrench Calibration
Old Feb 9, 2007 | 10:34 PM
ArcticHonda's Avatar
Default Torque Wrench Calibration
Anyone know where I can take my t. wrench to get it calibrated?? Just bought a used one....thanks.
Old Feb 10, 2007 | 01:25 PM
Tony1M's Avatar
Default RE: Torque Wrench Calibration
If you want some assurance without extreme accuracy, you can use a torque wrench of known accuracy to tighten a bolt to a mid-range torque, then put the wrench of unknow accuracy on there and see how tight it "says" the fastener is. If it's close, your laughing.
If it's not...........
What type of wrench do you have - dial, "click", or deflecting beam (long needle with scale near handle)?
If it's a delflecting beam, just make sure theneedle is pointing to zero at rest. These are simple,very reliable and, as long as you have a good view of the scale, accurate.
If it's a clicker, they're notoriously inaccurate, and you'll likely spend more for the calibration than the wrench is worth. Buy a replacemnet clickerand hope it's accurate off the shelf. Better still, replace it with the beam type.
If it's an expensive dial type, you'll still pay quite a bit for a calibration, but it'll be cheaper than buying another expensive oneof the same type.
Usually places that sell expensive torque wrenches can tell you the name of a local place where it can be calibrated. If you do indeed go for a calibration, tell them that you don't need a certificate of NIST traceability - you just want to know that it's accurate for you own peace of mind. Maybe they'll calibrate it for less money if they don't have to go the paper-trail route.
Old Feb 10, 2007 | 05:31 PM
Clamp a socket or short extension in a vise, so the wrench sits vertically. Wrap a string or something around the handle, around some kind of pulley, & hang weights of the string. Measure the distance from the center of the socket to the place where the string is. Torque is weight x distance.
This assumes you know (REALLY know) the weight of your weights. A gallon of distilled water is8.34 pounds and the plastic bottle doesn't weigh much.
Dang, I was really stupid on that one. (I never work in gallons.) 62.4 pounds per cubic foot. Not per gallon. I fixed it...
[sm=imsorry.gif]
Old Feb 10, 2007 | 06:07 PM
19Accord97
62.4 pounds?! I must be super strong since I can carry four at one time!!
jk!
Old Feb 10, 2007 | 06:10 PM
Tony1M's Avatar
ORIGINAL: JimBlake
This assumes you know (REALLY know) the weight of your weights. A gallon of distilled water is 62.4 pounds and the plastic bottle doesn't weigh much.
per cubic ft
Tony1M
Nov 10, 2023 03:57 PM
Redclift37
Apr 3, 2014 10:38 PM
RobinsonRicer
Mar 6, 2013 10:35 AM
Hannibal
Apr 30, 2012 06:11 PM
00AccordLX5spd
May 23, 2007 01:29 PM
