TPMS System
Old Apr 7, 2012 | 12:53 PM
rah140's Avatar
Default TPMS System
I have a 2012 Honda Accord EX-L V6 and I had to replace the TPMS Sensor on one wheel. The system was not reprogrammed and the system seems to be working fine afer driving about 30 miles sinnce installation. Will my TPMS system light eventually come on after changing one of the valves and not reprogramming the system?
Old Apr 7, 2012 | 01:23 PM
crispin's Avatar
Why isn't the dealer handling all this for you seems like that should all be covered under warranty?
Old Apr 7, 2012 | 01:28 PM
rah140's Avatar
Because I damaged the whee,l so I replaced it along with the tpms valvle and I just want to know it the tpms system light is going to eventually go on because the system wasn't reprogramed afer I changed the valve.
Old Apr 7, 2012 | 05:58 PM
Did a tire shop replace the wheel or tire and the tps?
Old Apr 7, 2012 | 06:05 PM
rah140's Avatar
They just mounted and balanced the tire.
Old Apr 7, 2012 | 06:20 PM
Well I'm thinking you are ok.....drop the air pressure to ~25 psi and see if the light comes on......where did you get the sensor?
Old Apr 7, 2012 | 06:23 PM
rah140's Avatar
from the honda dealer
Old Apr 7, 2012 | 07:13 PM
Was the original TPMS sensor damaged along with the rim/tire? Usually, the TPMS sensor can be re-used, although it is recommended to replace the washer on the TPMS nut and the grommet on the valve stem.
If they replaced the original sensor with the new one and the new TPMS sensor I.D. number was not programmed in; then, yes, the TPMS indicator bulb should eventually light on the dash.
Old Apr 8, 2012 | 08:47 AM
rah140's Avatar
ok. I didn't have a small torque wrench on hand for the tpms valve installation. Will this cause a problem because I didn't tighten the nut to factory specifications?
Fish Hunter
Apr 18, 2013 11:16 AM
gonefromparker
Nov 4, 2009 10:17 PM
bobz
Sep 27, 2008 11:57 PM
cigarlvr
Aug 1, 2008 08:57 AM
accordion
Feb 23, 2008 03:01 PM
