tranny shifts early
Old Aug 25, 2010 | 06:40 PM
turbo accord wagon's Avatar
Default tranny shifts early
my tranny shifts at 5750 rpms. anyone have this problem or know why it does it? could it be that i need to adjust the kickdown cable? or possibly be something else
Old Aug 25, 2010 | 06:46 PM
also my tranny shifts really hard from second to third and back down. it only happens when i'm sitting in traffic and having to speed up and slow down. someone told me the solenoids could need to be cleaned. all others shift good. its an auto
Old Aug 26, 2010 | 05:36 AM
g22cd5's Avatar
Supper Moderator
what's the year and trim is your accord?
The downshifting can and might be bad mounts.
Do you have OEM air box? CIA SRI??
For one f22 engines stop making power at 5800rpms anyways. My accord use to only shift at 5800rpms when I had my OEM air box. After installed SRI it would rev to 6000rpm at WOT then change gear but it would kinda struggle from 5000-6000rpms. When I got my CAI it would shift still a 6000rpm at WOT but didn't have the struggle for tho's last 1k RPMs.
I also have my TB cable tighten so when I'm at WOT my TB plate opens all the way.
I don't have any crazy mods done to my DD cb7
f22a1- Just CAI f22a4 header NGK blues spark plug wires with NGK plugs
Old Aug 26, 2010 | 07:23 PM
its a 94 ex wagon. i used to have a 94 sedan and it would redline no problem. the CAI is on order. all plugs and wires are new ngk. Where can i find the mounts and how do i tell if they are bad?
Old Aug 27, 2010 | 06:21 AM
piggylover1985's Avatar
try power brake it with the hood open and have your friend watching the motor, if it jump higher than 1 inch or so in forward or reverse, then the mount could be bad.
Old Aug 27, 2010 | 06:14 PM
oh the motor mounts, sorry i was thinking you were talking ab tranny mounts, that's why i was confused. i'll check tomorrow. could the solenoids need to be cleaned?
Old Aug 27, 2010 | 06:54 PM
Its not a bad idea to clean the solenoids and the screen.
I would also adjust that cable between the throttle body and the transmission.
Old Aug 28, 2010 | 07:24 PM
how do i clean the solenoids and the screen?
jtimc7
Jan 29, 2013 04:31 PM
rpowers2002
Feb 21, 2010 08:16 AM
wish234
Apr 2, 2009 12:15 PM
jose310
Mar 15, 2008 12:07 AM
superballz00
Nov 13, 2007 09:53 AM
