transmission delay 2 seconds before going into drive
the car was in a minor accident and the had removed the air filter assembly and front end...The Code was P0962 Pressure Control Solenoid which was replaced with a new one and check engine light and Flashing D was gone. There are no codes on the system and car has going through all monitors and everything is reset...I have ordered both pressure switches from the dealer along with the Transmission Fluid for a Drain and Refill.
I would really appreciate your help
