transmission fluid is barely on dipstick..is it really low??
Old Jul 13, 2006 | 10:33 PM
newaccord99's Avatar
Default transmission fluid is barely on dipstick..is it really low??
Have car running and dip it in and pull it out....barely on the first hole.....isnt it supposed to be up to the 2nd...the dipstick doesnt say anything..
should I add to it? and do you really add the fluid throught the dipstick hole?
thanks
Old Jul 14, 2006 | 12:13 AM
Chiovnidca's Avatar
Default RE: transmission fluid is barely on dipstick..is it really low??
The car should be sitting on level ground with the engine off when checking the oil and trans fluid levels.
Old Jul 14, 2006 | 12:38 AM
are u sure i was always told u have it idling then check it....thats what it says on my mercury cougar??
Old Jul 14, 2006 | 01:06 AM
mbo1985's Avatar
Yeah, you really need to add fluid through that dipstick hole. A narrow funnel is a nice tool for that job!
Old Jul 14, 2006 | 01:29 AM
Most non-Honda cars check auto tranny oil when it's warmed up & idling. Honda is pretty unique for auto trannys. Warm up the car, shut the engine off, then check it. Says so in your owner's manual.
Check it properly then add fluid only if you need to.
Old Jul 14, 2006 | 02:16 AM
deserthonda's Avatar
a couple of things.........first of all i gather car is a 99 is it an I4 or V6 ??.........if it is I4 you add fluid from the dipstick..........if it is a v6,, you need to remove the 17mm plug that sits on top of tranny and add fluid from there...the dipstick tube is way too small
second,, just for your future reference CHIOVNIDCA ,, is very knowledgable when it comes to Hondas so you can rely on his suggestions , and like other members said.......
yes you do chk the fluid with engine OFF,, on a level surface ......Now if it is low , I would not just add fluid , you got to find out the reason why it is low.........have you checked for leaks??
Old Jul 14, 2006 | 09:24 AM
Chiovnidca's Avatar
ORIGINAL: newaccord99
I just assumed you had a honda, since your posting on an accord forum.
Old Jul 14, 2006 | 12:44 PM
YeuEmMaiMai's Avatar
V6 will not show ANY fluid on dipstick when running. Like the others stated, check fluid with engine off and car on level gground
Old Jul 16, 2006 | 08:00 PM
so if i need to add some where do i get it from do i really have to go to a HONDA dealership or does a local shop like autozone sell it? if so whats italled...thanks
Old Jul 16, 2006 | 08:15 PM
my opinion for whatever is worth............
find out why tranny fluid is low,is there a leak ??? if leak repair as needed .......If no leaks , I would not add fluid to dirty fluid
i would drain the tranny and put 3 qts of new fluid in there........buy the fluid at Honda Dealer use only ATF-Z1
haoleflip719
Sep 22, 2024 12:22 AM
kttn
Jan 6, 2015 10:45 AM
dpotter
Dec 16, 2013 12:51 AM
HondaAccordNewb
Oct 18, 2007 06:51 AM
tjjtwo
Oct 10, 2007 09:13 AM
