Transmission Fluid Change
Old May 17, 2021 | 09:34 AM
pmay805's Avatar
Default Transmission Fluid Change
I have a 2017 Honda Accord EX-L V6 with a 6 speed automatic transmission. At 54k miles it indicates that I need to change the transmission fluid.
My question is whether this message is based on any analysis of the fluid within the car's mechanics or just a mileage decision?
Also, would this just be a drain and refill?
Thanks for any input.
Old May 17, 2021 | 10:46 AM
The engine-oil intervals are based on monitoring your driving habits, so I suspect the ATF interval is also based on something like that. It is NOT based on any in-situ measurement of the fluid itself.
Old May 17, 2021 | 11:48 AM
UhOh's Avatar
Originally Posted by pmay805
I have a 2017 Honda Accord EX-L V6 .... At 54k miles it indicates that I need to change the transmission fluid.
The uniform suggestion on the forum seems to be use Honda brand fluid for best tranny longevity.
Since your service is a lower mileage initial service (in my eyes) do what your dealer recommends, which is likely a flush. On other cars (Subarus for me) these run >$220, last time I had it done; expensive, but it's reassuring to see the clean fluid come out at the end - knowing it's all fresh fluid.
Old May 18, 2021 | 12:32 PM
It should be a drain & fill. Honda transmissions don't like to be power-flushed.
However, some dealers use the term "flush" when they are actually doing a drain/fill.
Old May 19, 2021 | 10:02 AM
pmay805's Avatar
Thanks Jim,
My Honda manual says this change requires 3.3 quarts. Not sure if that is for full flush or not. Just don't want to buy a quart that I won't use. What are your thoughts?
Old May 19, 2021 | 10:37 AM
shipo's Avatar
Thanks Jim,
That is for a simple drain and refill; if you want to replace all of the ATF in the unit (not really necessary), do the drain and refill three times over the course of a few days.
Old May 20, 2021 | 03:50 PM
At 54k miles and you're not seeing any problem? Just the maintenance reminder to do this? If so, I'd just do a single drain & fill so buy 4 quarts of Honda ATF & pour in 3 quarts & a little bit more. Then use the transmission dipstick to get the ATF to the correct level.
Doing 3x drain/fill cycles is something I'd only recommend for certain things:
- If you have 100k miles or more and have never changed it.
- Mistakenly put some no-name ATF that says it's good for "all brands".
- ATF is really dirty and you have some actual symptoms of bad shifting.
Old Jun 7, 2021 | 11:52 PM
Steveolv's Avatar
Default Drain and fill volume.
When I do a d&f I just replace the amount that drained out. Typically 3 qts. 98 Accord 3.0 4sp auto.
Thanks Jim,
Raccoonrider
Jun 8, 2021 12:27 AM
coolaccord
Oct 5, 2014 11:15 PM
JMac
May 3, 2012 09:53 AM
cryptonate
Mar 8, 2010 03:12 AM
62maxx
Nov 21, 2006 12:04 PM
