Transmission Fluid Filter
Hi,
I recently got my car's transmission flushed by a mechanic. (I did the drain/fill X 3 kind of flush. Used genuine honda fluid). The mechanic suggested that I need to get a filter installed on a hose/pipe (not sure which one) because Honda Accord 99 transmissions don't have filters in them. He suggested to purchase the filter at the dealer's and he would be able to install it for me.
Any idea what he was talking about? Have any of you guys done this on your car? Is it a good idea?
Thanks for your help.
Indy49
Indy49
There is a filter kit that is supplied with reman trans from Honda.
The filter is installed in line from the trans to the trans cooler located in the bottom of the radiator.
FYI the trans DOES have an internal filter, though it isn't a serviceable item.
ORIGINAL: jeepwm69
Hondadude, so would you say adding one is a good idea or no?
MessAround
Aug 13, 2011 09:45 AM
Special_K
Aug 12, 2011 04:16 PM
