Transmission Fluid Filter
Old Nov 30, 2008 | 09:30 AM
indy49's Avatar
Default Transmission Fluid Filter
Hi,
I recently got my car's transmission flushed by a mechanic. (I did the drain/fill X 3 kind of flush. Used genuine honda fluid). The mechanic suggested that I need to get a filter installed on a hose/pipe (not sure which one) because Honda Accord 99 transmissions don't have filters in them. He suggested to purchase the filter at the dealer's and he would be able to install it for me.
Any idea what he was talking about? Have any of you guys done this on your car? Is it a good idea?
Thanks for your help.
Indy49
Old Nov 30, 2008 | 11:55 AM
hondadude's Avatar
Default RE: Transmission Fluid Filter
There is a filter kit that is supplied with reman trans from Honda.
The filter is installed in line from the trans to the trans cooler located in the bottom of the radiator.
FYI the trans DOES have an internal filter, though it isn't a serviceable item.
Old Nov 30, 2008 | 03:54 PM
jeepwm69's Avatar
Hondadude, so would you say adding one is a good idea or no?
How much did the dealership quote you to install the external filter indy49?
Old Dec 1, 2008 | 09:32 AM
falkore24's Avatar
While you are at it, adding a tranny cooler wouldn't be that hard. The model for your car is Hayden 403.
Old Dec 1, 2008 | 05:22 PM
hondadude's Avatar
ORIGINAL: jeepwm69
all the filters in the world won't help anything when the differential bearings shell out.
john_pyro
Jul 16, 2019 11:45 PM
MessAround
Aug 13, 2011 09:45 AM
Special_K
Aug 12, 2011 04:16 PM
bjr001
Mar 5, 2010 07:31 PM
surajsss
Sep 17, 2007 11:28 AM
