Transmission Fluid Leak
Old Feb 22, 2022 | 07:47 PM
fivestorys's Avatar
Default Transmission Fluid Leak
I have transmission fluid spraying out of the center hole circled in the attached picture.
I thought I damaged the coolant hose when moving it to fit my socket when removing the solenoid. I replaced the hose, but now it appears the fluid is blowing out of this center hole rather than the hose.
I can't find where there is a bolt, washer, or gasket that should go here. I can't even find what this would be called.
Old Feb 22, 2022 | 10:19 PM
What year model engine (v6 vs 4cyl) and transmission (auto vs manual) are you dealing with?
Old Feb 22, 2022 | 10:26 PM
fivestorys's Avatar
2002, V6 3.0 automatic
Old Feb 22, 2022 | 10:48 PM
I'm not very familiar with the V6 transmission layout. I just googled 2002 accord v6 transmission.
jdmenginezone had a used one with a lot of pictures. Maybe you can find what should be in the hole that is leaking transmission fluid.
Old Feb 25, 2022 | 09:21 PM
The hose on the transmission is for the breather/vent. It probably has to do with the vent.
Old Feb 25, 2022 | 09:43 PM
fivestorys's Avatar
I replaced the hose, because I initially thought that's where the leak was. Number 6 in the above diagram. But the transmission fluid is coming out of the plate next to the hose...the middle hole. Are you saying that's a vent?
Old Feb 27, 2022 | 08:49 AM
Can you post a picture of that area in your transmission?
rockhoundrob
Oct 28, 2015 08:07 AM
mclasser
Jan 17, 2015 11:44 AM
dabro22
Aug 29, 2011 04:21 PM
6hhhh6
May 31, 2010 01:27 PM
longpatch
Nov 19, 2007 07:48 PM
