Transmission problem????
Old Jun 1, 2007 | 01:45 AM
Dairus's Avatar
Default Transmission problem????
Guys,
Greetings I have an Honda Accord automatic transmission Ex 98. The problem that Im having is that when I try to switch from Parking to Reverse neutral or Drive it won't let me it stay stuck. I really don't know why is it doing it. most of the times I got to remove those 2 screw beside and sometimes doesn't do nothing just to keep fighting till I get her to the shift desire. I will really appreciate any help cuz every time if I wish to go out or anywhere the sameproblem.
Many Thanks
Old Jun 1, 2007 | 05:57 AM
Chiovnidca's Avatar
Default RE: Transmission problem????
It gets stuck in park? Do your brake lights work when it's doing that?
Old Jun 1, 2007 | 01:18 PM
Dairus's Avatar
Hi,
I was checking my brake lights and I saw that the upper one wasn't working. Do you mean cuz of the fuse light Im having that problem???
Thanks
Old Jun 1, 2007 | 10:58 PM
Dairus's Avatar
Hello
I replace the light bulb and seems to work now.
Thank you
Old Jun 2, 2007 | 06:15 AM
Chiovnidca's Avatar
ORIGINAL: Dairus
Hello
Thank you
LOL, the bulb wasn't your problem.
Old Jun 2, 2007 | 10:10 AM
You may still have a flaky switch on the brake pedal. The bulb shouldn't matter.
The switch on the brake pedal does BOTH - switches the brake lights, and tells the shifter interlock that you're stepping on the brake pedal.
trouble
Aug 21, 2012 07:46 PM
MessAround
Aug 13, 2011 09:45 AM
mamarotta
Nov 13, 2010 11:10 AM
kellysa111
May 1, 2009 08:35 AM
Krashnpa
Jan 15, 2006 12:57 PM
