Transmission woes
Old Jun 7, 2013 | 10:03 PM
ggarcia155's Avatar
Default Transmission woes
I lost the reverse gear in my 91 Accord AT. I replaced the trans with one from a 93 Accord and now have an unusual problem. When the car is started and driven it runs fine until you accelerate usually after about 2-3 mins. At that point the rpms flutter a bit and the car acts like it's "missing." You can also hear a relay kicking on and off under the dash(fuel relay maybe?). If you accelerate the car will go, but the problem returns immediately as soon as you start cruising again. The cruise control works even with the car "missing" so I ruled out the VSS. I jumped the solenoids and all four have good hard clicks, not weak. No engine check lights, no flashing S indicator, no D4 flashes. Definitely feels like an electrical or computer problem. I am stumped. Any ideas?
Old Jun 8, 2013 | 08:48 AM
I've move this to General Tech. Please do not post questions in the DIY Section
street_ruler
Aug 7, 2013 10:38 AM
ggarcia155
Jun 9, 2013 07:00 AM
Ice D
Jun 30, 2011 08:48 PM
richomundo
Feb 26, 2007 09:11 PM
Brendo613
Feb 23, 2006 07:26 PM
