tweak the timing?
Old Jan 4, 2019 | 10:31 PM
sasha's Avatar
Default tweak the timing?
I had the timing belt replaced on my 96 accord 2.2 non vtec and all seems normal. the engine has 211k and i thought it could use some tweaking of the ignition timing for better 'pick up' after reading different articles on the web i am seeing the ignition timing is NOT adjustable? is this true?
Old Jan 5, 2019 | 07:19 AM
Pretty sure that the dist is not adjustable on the 96 and up Accord 4 cyl.
Old Jan 5, 2019 | 07:34 AM
The spark timing doesn't come from the distributor anyway. That comes from a sensor down at the front crankshaft pulley.
Old Jan 5, 2019 | 07:46 AM
shipo's Avatar
I think the OP may have been reading something about old school distributors which were set via a timing mark and used a vacuum advance to bring the timing forward when at steady state speeds for better fuel economy.
To the OP, it is highly unlikely advancing the timing will improve acceleration; what is more likely, if you were to figure out how to perform the advance, is you would induce detonation during acceleration, and left unchecked long enough, said detonation will damage your engine.
Old Jan 5, 2019 | 08:53 PM
The 96 accord was the first OBD2 accord and the distributor housing should have holes instead of slots. The PCM on the OBD2 accord takes several inputs and electronically adjusts timing.
Up through the 95 model, the distributor had slots on the housing where it bolts to the engine. You could adjust the angle of the distributor to set the base timing by disabling the ECU from adjusting timing. This was done to make sure the ECU could advance/retard the timing within a designed range.
Old Jan 6, 2019 | 03:42 PM
sasha's Avatar
Thanks, that is what I was wondering.
I did mean to say, 'set the base timing up'
The distributor mounting holes looked slotted, I'll double check tomorrow
Thanks fellas!
Old Jan 6, 2019 | 05:15 PM
The Toecutter's Avatar
Thanks fellas!
If it's anything like my 97 Accord w/2.2 L non-vtec, it'll have 2 slotted holes, and 1 solid hole.
RobinsonRicer
May 6, 2013 12:39 PM
5.0stang
Apr 23, 2013 06:37 PM
ss485
Feb 23, 2011 08:18 PM
Jay 3rd
Feb 17, 2008 10:54 PM
Tony1M
Apr 1, 2007 05:42 PM
