update and new 1989 accord issue - seeking advice
Old Apr 12, 2014 | 08:53 AM
Been a while since I was under one of these. I "think" you'll have to get at it from under the car.
Those pic's are from one of the many shop manuals I have for the 3rd gen Accords.
Old Apr 14, 2014 | 09:09 PM
huntersdl's Avatar
ok i have a honda salvage yard that found an unloader, thermo a and b. since i broke the one with 3 nipples i have no choice. Will start with that and i guess while im under i may as well replace the other .. .IF i can even get to the parts from under... i can barely find and see the thermovalves from up top and doubtful i can get a small crescent wrench in there to loosen them. Anyone know if they or lefty loosy like you would expect or one of the backwards bastards?
Old Apr 15, 2014 | 07:23 PM
They use to sell PVS (ported vacuum switch) sockets....many moons ago. Some may rent them still? Think of an O2 sensor socket, just a larger "slit" and the right size hex.
Old Apr 16, 2014 | 08:07 PM
huntersdl's Avatar
Geeze had no idea those were also called ported vacuum switches... All the stores carry them new adn look exactly the same... the 3 port and two. So the 3 port is thermovalve A... adn they have two options for the 2 nipple ones.. do you happen to know what temperature theromovalve B operates at? The two parts are different temps.. one being 120 degrees and one 160.
Old Apr 17, 2014 | 07:47 PM
huntersdl's Avatar
parts came in today can i test these NOT installed on the car? The unloader i push the little metal pin and it slowly comes out... and i hear a hiss when i push it in. and the Thermo a and b.. any sugggestions?
Old Apr 20, 2014 | 08:37 PM
huntersdl's Avatar
Good news. Changed thermo A and it no longer hung at 2000. Was down to 1400 and adjusted screw now at 800 or so. Now battery light wont go out lol...new battery so have to check alternator. Thanks everyone
Old Apr 21, 2014 | 06:58 AM
  #17
Progress
Can't seem to find the spec's on "B"? Usually there is a stamping on the brass/metal base of them - look at the "hex" part for a marking might be in celcius.
If it turns out to be the alt - do not follow the "book" that says you have to pull the cv shaft to change it. I can walk you thru the steps to change the alt without removing the cv shaft.
Old Apr 21, 2014 | 06:48 PM
  #18
huntersdl's Avatar
Ill take suggestions cause I tested it today and no charging at all
bjpomeroy
Jan 17, 2015 01:47 AM
Dan_99accord
Aug 27, 2013 11:59 AM
maciekmaciek19
Apr 4, 2011 02:24 AM
driscollmv
Jan 14, 2010 12:57 PM
tom15425
Jan 8, 2006 04:09 AM
