Using battery with flipped terminals
Old Jan 18, 2016 | 12:29 PM
glp65's Avatar
Default Using battery with flipped terminals
Hi all,
My battery (Kirkland) doesn't seem to hold a full charge anymore, so I went to Costco to exchange it. Found out that they changed over to Interstate brand. My 1990 Honda Accord LX needs a group size 24, but they only carry the 24F that has the terminals flipped ( + - instead of - + ).
Would it be okay to just buy the 24F, turn it around so that the terminals are located on the proper side and install it that way. I remember having had to do that for one of my batteries once before. It's probably a stupid question, but I just wanted to make sure that it wouldn't be a problem.
Thanks!
Old Jan 18, 2016 | 02:13 PM
No real critical functional problem, but there's 2 things to check...
I don't know if there's anything about the bottom of the battery that would prevent it from going into the tray in that orientation.
Then I expect you would struggle to get the cables attached across the battery. I never had a 1990 but I expect the cables don't have an extra inch to reach across to the posts that way. It's important to consider how the engine moves & shakes in it's mounts, during driving.
Old Jan 18, 2016 | 04:19 PM
glp65's Avatar
Thanks for the reply, JimBlake! It looks like there's enough cable length from each side to reach the battery posts if I change the orientation.
Old Jan 18, 2016 | 07:21 PM
Just me and the too many years I've been in the automotive aftermarket - pushing 30 years now.
I'm surprised that the 24 would not be offered if there is enough slack in the cable to make the 24F work.....go for it. again the only difference is the position of the terminals on the battery.
letsclique
Jul 20, 2012 10:03 PM
MessAround
Jan 1, 2012 09:01 AM
Redcap
May 11, 2008 04:33 PM
new2honda
Feb 7, 2007 12:21 PM
