valve adjustment gap? 2004 k24
Old Aug 24, 2023 | 01:00 PM
75Gremlin's Avatar
Default valve adjustment gap? 2004 k24
I've heard set the valves to the middle of the gap clearance range. Also read set the exhaust valves to the loose side of the gap range as the exhaust valves tend to tighten over time.
Vehicle bought recently has 246k miles. Have extensive records but may never have valves checked or adjusted. Figure its due for a valve adjustment, but some say not needed except when engine is noisy. I'd always understood that tight valves are not noisy.
My plan is to check the gap and leave any valve that are within gap spec alone.
What say ye? Thanks in advance for any help!
Old Aug 25, 2023 | 10:04 AM
I think all the valves will tighten over time due to normal wear, so set the gap within range using your feeler gauge.
Also check the gap before you adjust to get an idea of where you are starting. My TSX has basically the same engine and all the valves were tighter than spec when I did my first service at ~100K miles.
jeffbantle@gmail.com
Aug 28, 2019 07:51 AM
andrew7673
Feb 15, 2014 09:17 AM
lvp0412
Jan 30, 2011 09:08 AM
weekendwrench
Dec 14, 2007 05:24 PM
weekendwrench
Jan 2, 2007 11:56 PM
