valve cover gasket
Old Feb 18, 2008 | 10:55 AM
cbinva's Avatar
Default valve cover gasket
Hello I was wondering how difficult it is to change the valve cover gasket on my 92 honda accord.Are there any tricks to it and should I use dealer parts or auto zone parts.Thanks
Old Feb 18, 2008 | 11:00 AM
falkore24's Avatar
Default RE: valve cover gasket
No tricks. Just use gasket sealer .... oh, 1 small trick, try to use a continuous bead of sealer, it works better that way. Also, you need to know how much to torque the bolts when putting them back on. If you are doing the valve cover gasket, you should do the spark plug tubes at the same time.
Old Feb 18, 2008 | 11:29 AM
MikeT's Avatar
ORIGINAL: falkore24
When I put mine on, I asked Honda about sealer and they said it is not needed. I ended up not using it but I guess it couldn't hurt.
Old Feb 18, 2008 | 12:35 PM
cbinva's Avatar
Thanks for the reply does the gasket and all come together not sure what you mean about the spark plug tubes does anyone know how much to torque the bolts thanks
Old Feb 18, 2008 | 01:43 PM
The holesfor the spark plugs have their own little round gaskets, physically separate from the outer rim of the valve cover. Most of the time a VC gasket "set" comes with all of that and the little rubber grommets & washers for the bolts too.
I put a Fel-Pro brand valve cover gasket on a '92, it was a bit oversized. I had a bit of a handful keeping that gasket from bulging out at one place or another as I set the valve cover into place. Butit wasn't that bad - ittook less time than going to return it & then driving to a dealer. And it didn't leak...
I forget the bolt torque, but I guess they're pretty easy to break. So look it up.
Old Feb 18, 2008 | 01:53 PM
oma93's Avatar
You really should do the lower plug tube seals too. It's not all that difficult. Downlaod the manual for your car, it will help a bunch!
IIRC the valve cover bolts get torqued to 9 foot pounds.
Old Feb 18, 2008 | 04:30 PM
Gopal's Avatar
I tap the valve cover with a rubber mallet before torquing the nuts. Helps the gasket settle in.
crvone
Dec 29, 2007 02:13 AM
thunder_x
Jul 9, 2007 11:57 AM
Fez
Apr 9, 2007 11:32 AM
richomundo
Mar 13, 2007 09:25 PM
PIGGEBANK
Aug 13, 2006 12:13 AM
