Valve cover gasket
Old Aug 29, 2008 | 03:15 AM
bambooyou's Avatar
Default Valve cover gasket
I am changing the valve cover gasket on my 2000 accord. Do i need to put RTV sealent on the new gasket when i put back the cover?
Old Aug 29, 2008 | 11:59 AM
Default RE: Valve cover gasket
If valve cover gasket fits in a groove around base of valve cover, only place that RTV Is needed is at the right angle corners where gasket crosses over the camshaft bearing housing. Put a spot of RTV at the four corners of the bearing housings and spread w/ finger. No RTV on the gasket itself. Most folks don't wait for the RTV to dry, but Honda is silent on this issue.
Make sure you put the spark plug seals into valve coverw/ open sides facing up. I've found that a large socketto match size of the seal makes a good tool to push the seals into final position.
Old Aug 29, 2008 | 05:24 PM
hondadude's Avatar
Old Aug 29, 2008 | 09:31 PM
bambooyou's Avatar
Thank yougentlemen for sharing your knowledge. I really appreciate with your info.
crvone
Dec 29, 2007 02:13 AM
thunder_x
Jul 9, 2007 11:57 AM
Fez
Apr 9, 2007 11:32 AM
richomundo
Mar 13, 2007 09:25 PM
PIGGEBANK
Aug 13, 2006 12:13 AM
