Very strange day
Old Mar 14, 2013 | 07:40 PM
firefighter44's Avatar
Almost A Senior Member
So again....abs trips, had an issue with a no start/power.....humor me, it costs almost nothing to clean/tighten the cable ends.
I did, I tightened the battery ground that day after realizing it had somehow came loose and the next day i disconnected both pos and neg and cleaned the terminals and connectors.
I've also checked as many of the body/engine grounds as i could find (im usually pretty ocd when it comes to keeping good grounds)
As for the abs it so very erratic, its comes on some times and doesnt most of the time and it seems to do it a little more when its cold outside than it does when its warm. theres never any codes when i check it.
I know all about it coming on when the alt goes out, Mine went out once and it among other things came on and then i replaced it and the new one went out an hour later then had 3 more bench test bad before i left with a "good" one. that one lasted 6 months and went bad so i took it back, got my money back and got one from somewhere else, which was about a month ago.
Old Mar 14, 2013 | 08:01 PM
I hear you loud and clear. Again, a wheel sensor, pump over run, ect will set and store a code. A low volatge will not....that is where I'm going. The "why" is always the fun
Old Mar 14, 2013 | 08:14 PM
i hear ya on that, its always possible that there is a ground ive somehow missed as well.
Is there a body/engine ground directly to the abs pump that you know of?
Old Mar 15, 2013 | 07:14 PM
To answer the ground question....g401/g403 are for the control unit- computer thing on the pass/right side. G351 is for the actual abs pump motor.
_livebyhonda_
May 20, 2020 04:39 AM
bladest
Dec 31, 2012 08:50 PM
Lunalobowolf
Oct 26, 2012 09:33 PM
Mike O'Connell
Jul 24, 2012 09:15 PM
zz28zz
Jun 13, 2009 09:17 PM
