Video: steering makes noise when engine cold and cold weather
Old Nov 11, 2014 | 07:21 PM
d0n's Avatar
d0n
Default Video: steering makes noise when engine cold and cold weather
Hi,
I have a 2003 Accord 6-speed v6 coupe.
Video of my issue is here:
only happens when the engine is cold. after it warms up it doesn't happen at all.
Thanks for the help.
Old Nov 11, 2014 | 07:27 PM
Probably due to air is entering the power steering pump through the inlet joint O-ring.
DIY Power Steering Pump O-Ring TSB - Drive Accord Honda Forums
Old Dec 8, 2014 | 01:11 AM
oldbeek's Avatar
mine did the same. Honda dealer wanted 750.00 to fix many things. There is an updated red o-ring at the inlet fitting on the pump. .89 cents and 5 minutes to change. Dealers suck!!!
Old Dec 9, 2014 | 05:42 PM
EXV6NIGHTHAWK's Avatar
A LOT of people got screwed for pumps with this issue. Luckily, I knew about the o-ring before my pump started screaming one cold morning.
Old Dec 10, 2014 | 07:42 AM
Low PS fluid level will also cause this problem. Make sure fluid level is good and no leaks.
HYDRALOX
Dec 31, 2012 08:46 AM
justice37
Oct 26, 2012 06:45 PM
dunnskii
Feb 19, 2011 08:04 PM
crazymikeyo5
May 5, 2008 09:23 AM
AccordEX
Dec 4, 2006 02:09 AM
