VSA/ABS/BRAKE lights
Also I wanted to ask if you know how I can repair my hanging headliner? I had my car detailed and I think the person used a steamer & didn’t really know the damage it would cause. A week later my headliner started having pockets of what looked like air and it began hanging…now it’s worse.
I tried to reattach the original skin
did a $#!tty job of removing the foamy slime by reaching in the holes. Used spray adhesive. It did not want to stick in any places with a concave shape, and would not cover the corners. Was a $#!t show. Then in the morning most of it had fallen down. It was a miserable wasted effort.
The leopard print blanket on the other hand...
I removed all the handles and corner post trim and crap, cleaned the headliner very well, took out front seats, threw down a drop sheet, mopped on the weldwood (comes in a bucket) with a roller and brush. Let it dry a bit and reapplied a light coat, hung the blanket when it was still kinda wet because i couldnt apply it to the blanket and do the dry-bond between 2 coated surfaces.
Found the middle of blanket, found middle of car, hung it with some clips. Went to town with a Dry Narrow paint roller. Start in the middle and work out. Push firmly and stretch it into the concave shapes. If you get a wrinkle you can pull it back and try again. If the sauce dries too much you can put a little more as you get to that section. Dont overdo the sauce or it might seep out through the blanket and drown the nap.
Mine turned out perfect.
Asad Rafique
Jul 18, 2017 09:28 AM
