vtec solenoid p1259 code
Old Jan 19, 2013 | 06:54 PM
uawoody77's Avatar
Default vtec solenoid p1259 code
I had p1259 code and car would start missing at 3500rpm. Replaced solenoid from dealer and runs great now. The check engine light will not go away though. Tried unhooking battery didnt work tried restting with code reader and no luck said cant reset code. Any ideas?
Old Jan 19, 2013 | 07:04 PM
uawoody77's Avatar
Sorry I left out its a 2000 accord with 4 cylinder
Old Jan 19, 2013 | 08:10 PM
Moved post to correct forum. Read posting rules and don't post in DIY forum.
I believe 1259 is fault in oil pressure switch circuit; bad wire, connector, pressure switch, or ECU fault.
Old Jan 20, 2013 | 10:44 AM
uawoody77's Avatar
My code reader says p1259 vtec malfunction. It will not even allow me to reset the code.
Old Jan 20, 2013 | 12:19 PM
Make sure the ECM ground at G101 is firmly attached. Pull the No. 13 (7.5A) clock/back-up fuse in the passenger side interior fuse box for at least 10 seconds to try to reset the ECM/PCM.
Attached Thumbnails vtec solenoid p1259 code-1998-2000-accord-g101.jpg   vtec solenoid p1259 code-1998-2002-accord-ecm-reset.jpg
Old Jan 20, 2013 | 01:49 PM
Vtec has a pressure switch which can have fault P1259 as described. Get a manual and it will be clear.
Old Feb 9, 2013 | 02:29 PM
PositiveMaterial's Avatar
Guys, please be sure to check the wiring going into the Vtec solenoid. Make sure the wires are all connected to the proper places. It may seem simple, but this was the problem that was giving me the p1259 code.
TexasHonda
Nov 6, 2020 07:02 PM
gdmech22
Jun 30, 2014 06:09 PM
broadmoortech1
Jan 31, 2012 04:22 AM
wietgr
Aug 4, 2011 09:43 AM
AustinGT
Feb 8, 2008 10:53 AM
