water leak under passenger seat Accord96
Old May 18, 2009 | 10:28 PM
jjandshi
Default water leak under passenger seat Accord96
Water leaks around the plug indicated by the arrow. Thanks.
Old May 18, 2009 | 10:34 PM
jjandshi
Default Sorry the picture is here
Old May 19, 2009 | 07:04 AM
I think you'll just have to clean it up real good & seal with caulking.
Old May 19, 2009 | 12:01 PM
Is water leaking in from around the plug or is that where water drops from above?
If from above, the evaporator case is filling w/ condensate from AC use and running over. Drain line repair or evaporator clean-out needed.
Old May 19, 2009 | 12:16 PM
Tex, that's the left-side rear seat; looking in from the left-rear door. Water would have to run from the dashboard, cross over the center exhaust tunnel, then jump up to that place which is at a higher level then the front footwells.
djkurious
Mar 31, 2014 10:14 AM
Lovemy97HondaAccord
Mar 5, 2014 06:04 PM
jime
Oct 5, 2013 04:19 PM
Born Barb
Jul 14, 2013 05:45 PM
MysticBlueEX
Feb 18, 2011 06:55 AM
