water valve leaking
Old Aug 1, 2013 | 01:18 PM
sgull's Avatar
Default water valve leaking
On my 92 Accord I'd been mysteriously losing some coolant so borrowed a pressure tester for the cooling system and then discovered which is apparently and almost certainly coming from this "water valve assembly" as shown here, part #1. Honda Automotive Parts
The hoses going and from it are in good shape and the connections are good, but seems to be leaking from the plastic seam at the square bottom part of this valve. Ever heard of these deciding to leak, or does this seem like a freaky and unusual occurance? Anyways, I'll be taking it off to inspect it and the hoses closer, and probably end up having to get a new one of these valves I guess. Any comments appreciated. thanks
Old Aug 1, 2013 | 02:21 PM
Dr. Drivability's Avatar
if it makes you feel better, they all leak at some point in their lives. they are easily had and easy to replace.
Old Aug 1, 2013 | 04:03 PM
sgull's Avatar
After further closer investigation, it seems the leak was actually coming from the hose connection at the inlet side of the valve. I had recently replaced that particular hose with a 3/4" size, which is slightly bigger in size than the Honda stock size hose, and that just doesn't clamp down good enough to make the watertight seal over that valve nipple with the cooling system up to pressure.
AccordNation
Jan 7, 2009 11:14 AM
Accord12404
Dec 1, 2008 03:48 PM
Dairus
Apr 17, 2007 10:49 PM
joe592
Aug 10, 2006 01:51 AM
Illusive
Jul 30, 2006 02:10 PM
