Weird Electrical Issue?
Old Jan 26, 2023 | 07:24 PM
blob gnarly's Avatar
Default Weird Electrical Issue?
Ok, so I haven't resolved my Accura's stalling issue yet (as described in another thread)
So it's been sitting idle on the street lately. When I tried to start it yesterday the battery
was dead. I pulled it out and charged it on my charger for like 12 hours. It seemed
like it had reached a full charge, so I reinstalled it, cleaned and brushed the posts
and connectors, and everything seemed good. Dash lights came up, but when
I tried to start it, it would not turn over. Just that repeating clicking sound from the
starter motor. So I knew I wasn't getting enough cold cranking amps from my
freshly charged battery to properly engage the starter. Figured the battery was
done, so went ant bought a brand new one, dropped it in and it started right up
no problem. I drove to the supermarket, and when come out and try to leave
TOTALLY DEAD! . no instrument panel, nothing at all. Checked all fuses under
dash and under hood. All were fine. Nothing blown. WTF?
Old Jan 26, 2023 | 10:34 PM
Did the battery read 12.6 V or greater using a volt meter?
Old Jan 27, 2023 | 06:23 PM
I'm getting 12.64 DC reading on new battery, but now the instrument panel is not lighting up
when I turn ignition switch to second position. It lit up 10 minutes before. when I
installed the new battery, but now it won't.
And when I tried to start it, just that clicking sound again from the starter motor.
Same thing that was happening with the old battery. I had to get a jump start.
on a brand new battery just to get back home. How can that be?
Old Jan 29, 2023 | 08:58 PM
Something is draining your battery or you have some flaky battery cables/connections.
Old Feb 2, 2023 | 07:20 PM
The battery cables seem okay, they are hooked up tight, and there's no corrosion that I can detect.
However I was looking at the fuse block, and the three small wires that go into a connector in the
corner look a bit rusty. I jiggled them a bit, and now the instrument panel is lighting up again
when i turn ignition switch to 2nd position. I also pulled the relays and re-seated them.
Could there be unseen corrosion underneath the plastic fuse block?
Old Apr 19, 2023 | 04:06 PM
It was distributor
brihowdee
Dec 13, 2016 04:24 PM
illuminator77
Jun 8, 2015 01:06 AM
CarIdiot
Dec 20, 2011 07:54 AM
MMoreira
Oct 7, 2011 11:55 AM
leg_of_tape
Jul 16, 2010 06:19 PM
