Werid Transmission Problem?
Old Jun 16, 2007 | 07:03 AM
HondaRacer4Vtec's Avatar
Default Werid Transmission Problem?
Hey guys,
I got a really werid transmission problem wonderding if i could get some help. Will this is what basically happens, when iam goning to work i have to take Bear mt. Up here in new york. Anway if you dont know its alot of sharp turns. So when i have to make a sharp right turn, my transmission somehow losses its gear during the turn, so if i press the gas during the turn its like the car is in netural, the revs go up but the car is not going anywhere. Then as i start to staright out the wheel after the turn it does a hard jump back into the gear. as if i was neatrual droping it. The werid thing is that this never happens when i make a left turn or anytime else. It only happens when i make a right turn. Anyhelp will be appeciated. THX
Old Jun 16, 2007 | 09:29 AM
Rhoderman's Avatar
Default RE: Werid Transmission Problem?
How's the tranny fluid level?
Old Jun 16, 2007 | 10:20 AM
sir_nasty's Avatar
I would check your tranny fluid level as mentioned and if that's fine then you may be loosing your tranny.... that sounds like it's slipping to me... That's EXACTLY what a slipping clutch does.... and that year of car is known for it.....
Old Jun 16, 2007 | 10:37 AM
tranny fluid is max and very clean.
Old Jun 16, 2007 | 10:39 AM
sir_nasty's Avatar
When you checked the fluid did you smell it? If it smells a little burnt then that would confirm that it's slipping, if that's the case I'd trade off or sell that car fairly soon or start saving for a tranny rebuild.... I'm not trying to scare you or anything but there was a class action suit against honda because of those transmissions.... it's more common in the v6's but I have heard of problems with some of the 4cyl.... how many miles are on it?
Old Jun 18, 2007 | 08:47 AM
This transmission is a rebuilt transmission staright from honda dealer. i only put maybe 5,000 miles on it.I was wondering how werid that it only happens on a right turn, and it happens at anygear on a right turn. Never ever do i experince anytime during driving. Is it possible it could be a suspesnion problem. Maybe a axle. Also just a quick question, if it happens to be a transmisson prblem, i do get a 1 year, 10,000 mile warrnety for parts and service right? so i can send it back to them
Old Jun 18, 2007 | 09:15 AM
00AccordLX5spd's Avatar
Registered User
Take it to the Honda Dealer that provided the transmission ASAP.
Old Jun 19, 2007 | 11:31 PM
Ric Rock's Avatar
Get it checked asap, my tranny was slipping in and out of gears and even going into neutral than jumping up a gear as it revs up. Not good my friend, its your tranny slipping, it only gets worse the more you drive it. Sorry to sound so negative. I just had mine rebuilt by honda because the warranty covered my ride, I was fortunate to still be covered. Car rides like new now
Old Jun 20, 2007 | 06:43 AM
YeuEmMaiMai's Avatar
if you are taking the corner really hard it is possible for the trans fluid to move away from the pickup for the pump. My 94 did that all the time when going up a clover entrance ramp at 40-45mph..... if you are taking the corner at excessive speed, slow down if you are taking the corner at posted speeds, go to the dealer asap
unless your car was salvaged for some reason it comes with a 7 year 9 month or 109K transmission warranty. If you put in the trans yourself (paid for it) it SHOULD come with a 3 yr 36K mile warranty.
trouble
Aug 21, 2012 07:46 PM
MessAround
Aug 13, 2011 09:45 AM
kellysa111
May 1, 2009 08:35 AM
HondaRacer4Vtec
Nov 21, 2008 08:40 AM
Krashnpa
Jan 15, 2006 12:57 PM
