What is new "growl-y" noise?
Old Nov 9, 2011 | 05:17 PM
McDesign's Avatar
Default What is new "growl-y" noise?
'91 Accord. Low-pitched growl audible above ~40 mph; sounds like truck mud tires on asphalt.
No change in steering angle or dynamics, or braking, or engine rpm will affect the noise (same at 45 mph, whether in 4th gear or fifth). Came on suddenly; just Monday.
Noise is only related to road speed.
New calipers and pads two weeks ago; car lowered 2-1/2" about 6 weeks ago. Tires are a couple months old; pressure is normal.
I'm guessing R&P or inner CV joints. I have a new set of axles; will replace this weekend.
Any other thoughts?
Forrest
Old Nov 9, 2011 | 05:31 PM
crispin's Avatar
wheel bearings
Old Nov 9, 2011 | 05:54 PM
Find and open parking lot. See if the noise changes pitch or disappears when you steer towards the left or the right.
Old Nov 11, 2011 | 07:51 PM
McDesign's Avatar
Default Outboard race removal - help!
Great - made it through the week.
I'm convinced it's the wheel bearing; picked them up today, and I have a set of new axles to put in as well. So - it's all apart, except the outboard race of the front wheel bearings - I was able to press off the main bearing cassette.
How do I get it out? The Honda shop manual shows a puller, fine, but the race fits so tightly against the hub shoulder there's nothing to fit even a sharp-edged puller foot under it.
Should I just grind a slot with an angle grinder and expand it off?
Forrest
Old Nov 12, 2011 | 01:04 PM
McDesign's Avatar
Was able to grind a diagonal slot in the outboard inner race without damaging the hub too much, then split it off -
Forrest
Attached Thumbnails What is new "growl-y" noise?-100_2949.jpg   What is new "growl-y" noise?-100_2951.jpg   What is new "growl-y" noise?-100_2954.jpg   What is new "growl-y" noise?-100_2956.jpg
Old Nov 13, 2011 | 03:07 PM
McDesign's Avatar
Got it all back together - new rotors, wheel bearings, and drive axles. No noises!
Forrest
Old Nov 13, 2011 | 08:59 PM
McDesign's Avatar
Wasn't easy, tho -
Passenger side axle nut wouldn't come off with 5' cheater bar and a 3/4" drive 36mm socket, Decided since I was replacing the wheel bearings and axle, just to chisel it off, paring it away.
Then, once I got the upright off, the whole bearing cassette wouldn't come off the hub, even with my 20 ton press - the relief valve would just squeal.
I cut it entirely in half with an abrasive wheel in the side grinder - a mess!
Forrest
tboncher
Sep 17, 2014 05:46 PM
Reggi's-accord
Jun 6, 2012 07:17 PM
HondaAficionado
Nov 30, 2010 05:24 PM
Alekat
Feb 9, 2008 07:42 PM
kleptodathief
Oct 28, 2007 04:21 AM
