What oil seals to replace with timing belt on 02 4-cyl?
Old Dec 25, 2013 | 06:50 PM
mclasser's Avatar
Default What oil seals to replace with timing belt on 02 4-cyl?
I'm going to have my indy change out the timing belt, water pump and valve cover gasket and was wondering what seals to also change since everything will be accessible during this time. All my seals are 11+ yrs old and I know the timing seal is leaking a bit. After perusing Rock Auto, it seems the major seals are camshaft, balance shaft, timing and crankshaft. I know the front crankshaft seal should be easy to get to when changing the belts but what about the rear near the tranny? The Aisin kit I'm planning on getting has the tensioner + idler bearings w/springs which is nice.
Old Dec 26, 2013 | 08:45 AM
Suggest you only replace those seals that are leaking. The seals are not preventitive maintenance items in shop manual. It is easy to create a leak (scratch sealing surfaces, poor installation, etc) where none exists. Some may disagree w/ this position, and ultimately it's your call.
Engine crankshaft seal at transmission is not accessible w/o removing transmission.
Old Dec 26, 2013 | 10:53 AM
Roader's Avatar
And buy OEM seal(s). A few bucks more but much better.
Old Dec 26, 2013 | 03:06 PM
kris_loehr's Avatar
I would consider what your indy mechanic charges to change the unleaking seals and their skill level.
partialresponse
Oct 19, 2011 12:43 PM
PinkFloridaFlamingos
Aug 27, 2011 08:08 AM
ChicagoBob123
Sep 28, 2010 02:39 PM
Anazazi
May 17, 2010 11:35 PM
pelampe
May 3, 2010 11:47 AM
