What tool did you use to remove the slave clutch cylinder?
Old Jan 27, 2008 | 11:37 AM
Buktheng's Avatar
Default What tool did you use to remove the slave clutch cylinder?
I'm trying to remove the clutch pipe nut and there's like no clearance at all to put anything down there. I have a 10mm crow foot that's attached to a long extension for me to put down there to loosen it but it seems every time I try to loosen it, the crow foot would come off because it doesn't get a firm grip on it. What else can I use to loosen the clutch pipe? Let me know, thanks!
Old Jan 27, 2008 | 06:20 PM
hondadude's Avatar
Default RE: What tool did you use to remove the slave clutch cylinder?
95 accord? Take off the 2 12mm bolts holding the slave to the trans housing, and there is another bolt/tiedown holding the 'pipe' to the trans case. Then you can swivel the entire slave cylinder up towards the top of the radiator and use a 10mm line wrench to break loose the fitting.
1-Old-Man
Mar 31, 2014 10:06 AM
sparkleegrl
Jun 27, 2012 02:03 PM
magowie
May 13, 2010 06:03 AM
01Accord01
May 6, 2010 03:35 PM
nafango2
Dec 14, 2007 11:52 PM
